Question about LG LDF8812 Stainless Steel Built-in Dishwasher
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
BUZZ NOISE ON AND OFF CHECKED HOSE DOESNT SEEM TO BE CLOGGED ALTHOUGH CANT REMOVE END FROM WASHER SIDE CANT BLOW THROUGH, DISPOSAL LINE NOT CLOGGED I USE AN AIR LOCK TUB WONT DRAIN TRIED TO RESTART JUST BUZZES
  • 6,784 Answers
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Posted on Jun 19, 2009
SOURCE:
Lg d/washer about 8yrs old Oe code. Checked grey wire thiery. Cleaned hose filter etc. Was working fine moved house.Whats next.
A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain,
Feb 23, 2015 | LG Washing Machines
Dispenser is clogged
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 26, 2013 | LG WM-2277HW Front Load Washer
How to change drain pump and how much does it cost
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Check in this link for cost of the drain pump.
Sep 03, 2012 | LG WM2301HW Front Load Washer
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES...
hi Luis.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
Dec 12, 2017 | Whirlpool Washing Machines
LG washer getting an OE error. I have opened the pump and drained the water as well as ckeaned the filter...still not working propperly.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
Jan 30, 2011 | LG WM2101HW 4.0 cu.ft. Washer
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
DE error code
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Mar 28, 2009 | LG WM2277HBW XL Front Load Stackable...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
790 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
