Tip & How-To about RCA DIRECTV Satellite Remote Control
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
RCA DIRECTV Satellite Remote Control Logo
how to program the rca crcu 410 to the sankey tv, i lost the manual for the remote ....?
https://voxxintl.zendesk.com/hc/en-us/articles/225309547-Programming-the-RCA-CRCU410-RCU410-Universal-Remote-Control
Using Automatic Code Search on my RCA Remote
  1. Manually turn on the component you want to control.
  2. Press and hold the CODE SEARCH key until the remote's indicator light comes on. ...
  3. Press the component key you want to program. ...
  4. Point the remote directly at the front panel of the component you want to control.
https://www.manualslib.com/manual/313114/Rca-Rcu410.html
How to code search RCA universal remote rcrno4gr to DVD player.
  • 1Turn on the component you want to program.
  • 2Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
  • 3Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
  • 4Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
  • 5Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
  • 6Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
  • 7Press and release the STOP button to save the new code
  • Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1dVicIcMK
    how do i program my remote
    Things You'll Need:
    • RCA Universal Remote Control
    1. 1 Turn on the component you want to program.
    2. 2 Press and release the component button on your remote that corresponds to the component you want the remote to operate (TV, VCR, etc.). The illuminated ON-OFF button will turn on and remain on.
    3. 3 Press both the component and the ON-OFF buttons. The illuminated ON-OFF button will turn off, and then will come back on.
    4. 4 Release both buttons after the ON-OFF button turns back on. The button should remain illuminated.
    5. 5 Press and release the PLAY button. If the component does not respond after five seconds, continue to press the PLAY button every five seconds until the component turns off.
    6. 6 Press and release the REVERSE button when the component turns off, then wait to see if the component turns on again.
    7. 7 Press and release the STOP button to save the new code.
    Tips & Warnings
    • Each time you press the PLAY button in Step 5, the ON-OFF button blinks ten times and a list of 10 codes is sent to your component. This process continues until all of the code lists have been searched. If the component has not turned off after all codes have been searched, the ON-OFF button blinks four times, turns off, and the Auto Code Search is exited.
    • If you do not press the STOP button at the end, the new code will not be saved.
    Read more: How to Program an RCA Universal Remote Control ' eHow.com http://www.ehow.com/how_9191_program-rca-universal.html#ixzz1CzcjxWJw
    2answers
    RCA universal remote RCR312W
    Battry leaked on the steps for programing RCA remote. No Model # found. Is there a list and Picture I can choose from or a code list..... Help Bill
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
