Mother board ASUS P4GE-MX
Video memory integraded in the mather board IS...???
What memory card do i need in order to play some games in 3D for example AGE OF MYTHOLOGY i cant play because here says that it is not enougth... is ok with 128mb or more is required??...
Please let me know
Sorry for my bad english... im a spanish... speaker person..
from Lima Peru..
All drivers for your motherboard are available here... Scroll down, click on Download tab, select your OS and download the desired driver(s)!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
There is probably defective (damaged) or unsupported memory. Try one of your memory or both change, and if it does not work contact me But first check if your memory does not work only on your computer, so you too ye not buy new memory if you do not have another to interchange
Dear Sir Change the power related IC but your have no idea about the IC just send me a mother board we are Repair for this Mother Board Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok. Email:[email protected] Web: www.compudesk.in
Hi ****, you can increase you system speed slightly (Depending on the total memory speed of the card), by adding an AGP 4x video card & setting your bios to boot to AGP. See page 2-16 in your manual. Change, Init Display First to [AGP]. Doing this will disable the onboard - integrated video card. (Doing this will also free your system memory which is used to run the onboard graphics card). Increasing your system memory to its max of 2GB will help as well. Here is Crucial's memory link for your board. http://www.crucial.com/store/listparts.aspx?model=P4GE-MXYou should increase the CPU if at all possible to its max speed in-order to see an over-all increase of system performance. (This is not what you asked for, so I'll only include Asus link for supported CPU's, for the P4GE-MX motherboard). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4GE-MXDon't expect lighting speed but you will notice game playing speed much better. Programs should load much faster, ECT. Upgrading the AGP must comply with 4x/8x (+1.5volt only). Please see page 1-12 in your manual. Looking for XFX video card is best because it carries a lifetime warranty. Try this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150210 You can continue to search for an XFX Geforce cards. (Best on the market for their lifetime warranty).
Good luck ****!
Though the AGP slot is faster than a PCI slot, you may find an XFX PCI card with more video memory on it. Some even run DDR3 & DDR3 memory.
Mike
You better off getting an AGP card as your onboard graphics cannot be altered from what i can see and in any case will not be good enough to play most games as the 3d and shader won't is needed
