JVC UX-G70 Theater System Logo
Juanita Bowne Posted on Apr 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hooking up a blueray with hemi cables - JVC UX-G70 Theater System
Mohamed Alazhary
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Apr 20, 2014
Mohamed Alazhary
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
39317
Points
130
Jcv ux-g70 has no input digital or analoge ports.
BlueRay to Yamaha RX-V563
Did it ever work? Have you tried more than one input on the Yamaha? Will the BlueRay play through a different system? Seems unlikely that both the L & R cables are bad. If it's an optical cable, have you ruled out a bad cable?
3answers
How to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 • Netflix
Hdmi cables input 1,2,3,4 which input goes to the tuner, direct tv box, blue ray on vizio E550i-AO
The choice is entirely arbitrary. You may connect any accessory to any HDMI input. I recommend you connect the device you use most (probably your direct TV box) to HDMI 1, your second most frequently used device to HDMI 2, and so on, but it's really a question of your own preferences.
I have been using the tv with my sony ps3 to play my blueray dvd's etc. using an HDMI cable all of a sudden I cannot get a picture anymore. I think maybe my HDMI input on TV has gone bad. Can I...
yes you can replace the input board, but that is fairly expensive. HDMI cables can go bad, have you tried a different HDMI cable? Also try hooking up another device to the HDMI input to see if it might be in the Playstation3.
I am hooking up a new HDTV Yamaha YHT-292 LG 42" LH55 LG Blue ray Video Blueray to receiver to HDTV OK Satellite to receiver to HDTV OK Audio Receiver to FM tuner sound OK No sound from Satellite or Blue...
what audio cable type are you using, if its digital, you might have to assign that digital audio input with the video signal? go back over your cabling, and make sure the audio is not going to the wrong input and also check that SP/DIF (coxial or toslink) is enabled on the setup menu for the blue ray player and satilite, they normally disable it by default to save a little bit of power, also on a yamaha receveir should have a indication light that lights when a signal/decoding is in action, refer to your documention and trouble shooting section of the manual, hope this helps
Toby
Hooking up blue ray to Samsung 1080 DLP
if the tv is not a 1080p model it will not accept a blueray signal and the optical output from the tv only works thru its own tuner not with the inputs or cable boxes
Last night I finished hooking up my new Onkyo 7.1 HT-S5200 system. I used three HDMI cable to connect my TV, Blueray, and cable box. I upgrade the speaker wire to 16ga. The system is plugged into a Monster...
Turn everything off but the receiver. If it stays on turn another one on and see if it pops off if not continue. Most receivers have a pause start to prevent power surge. If it continues remove the protector and try the unit alone.
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
