Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub 350 paper cassete
  • Konica Minolta Master
  • 6,850 Answers
Yes what about it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 12, 2017
SOURCE:
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Any idea how to fix it? Is it the sensor or something else?
Open totally the cassete look for paper jam inside that might cover the sensor.
Remove cassete and look for black plastic actuator located on top of paper when cassete is inserted, it might be broken.
If all are ok , press as follow to reset the malfunction [off] while pressing [ Utility/Counter] turn [On] wait till the display appear then [trouble reset] it will appear OK on screen turn OFF/ON main power.
Aug 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 350. When I try to Copy There is a message: "Pleaser Reposition Original". What does it mean? How can I fix it? The paper is checked (size).
BEFORE YOU PUT THE CHECK ON THE GLASS, SELECT THE PAPER DRAWER YOU WANT TO COPY ONTO, THEN PLACE THE CHECK ON THE GLASS, THE COPIER DOES NOT KNOW THAT SIZE
Aug 28, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error code list
ARE YOU SURE ITS A BIZHUB 350 AND CODE C-0200
NOT IN BOOK
BUT 0202 THUR 0210 ARE PAPER LIFT ERRORS OR
Elevator Failure FOR THE PAPER TRAYS OTHER COPIERS ITS A HV PROBLEM
Jul 05, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 error code C11AO
Paper Lift failure of the finisher output tray. Did some one hit the finisher tray or did it hit something underneath? May require resetting the position of the finisher output tray, get qualified tech to do it !!!!.
Oct 15, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Jul 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error 270940 for Estudio 350
The A3 paper will not pass through the copier when the cassete is full. Copier states "Add Paper". When you push the A3 tray in you can hear a winding sound and then when you startt to copy it asks you to add paper.
Apr 16, 2009 | Toshiba e-Studio 350 Copier
Just a question as to the type of paper suggested to use.
Just a normal substance 20 paper will do for normal printing.
Dec 02, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
46 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
