Car was already wired get good bass but if i put my stereo over 20 the amp kicks out ? mono v12 alpine amp and 12 " type r in ported type r box wondering if i have the rca hooked up wrong the box has bridges the hookup so i assume that it would put me 2 ohm stable but not sure if i hookeed the rca s wrong or whats going on and why it kicks out ?
SOURCE: how do i run it 2 ohm stable
This is how 2 type r's are wired to one amp at 2ohms hope this helps dont forget to rate me thanks
Upfront Audio :)
SOURCE: Amplifier wont move subs
I dont know if this will help you but start at the deck and make sure that the outputs(RCA) arent crossed over to highpass and do the same at the amp make sure that its set for lowpass- set half gain -bass boost half gain- subsonic minimum - If that doesnt help try using an i pod with an adaptor that you can play it right into the amp this is to see if you are getting signal from the deck to the amp if it doesnt work with an i pod or mp3 plugged directly into it then you may have got you a blown amp going on- good luck with that
