Question about Janome Harmony 2039 Mechanical Sewing Machine
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  • 4 Answers
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Posted on Jun 19, 2009
SOURCE:
Re: Pfaff sewing machine, How do I use the zipper foot attachment?
It really depends on what your zipper foot looks like. There are several that can be used with the Pfaff machines.
Pfaff Zipper Foot 4
Pfaff 1067 zipper foot instruction Google Search
Jul 08, 2017 | PfaFF Sewing Machines
What type of foot do I need when attaching popper closure tape to a duvet cover.It needs to leave more space under foot for popper height.
You do NOT want to sew over the popper. Instead, use a narrow zipper foot and adjust your machine needle to stitch just on the very edge of the tape. Hitting a popper will definitely break your needle and possibly knock the machine out of time.
Be sure to get the right foot to fit your machine!
Your machine's zipper foot may not look like this, but it should give you the basic idea.
How to Use Zipper Foot Sewing Parts Online Everything Sewing Delivered...
Zipper Foot Adjustable Low Shank 55411
Oct 23, 2016 | Sewing Machines
How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
Jul 07, 2012 | Singer Inspiration 4205 Mechanical Sewing...
Have lost the zipper foot for a pfaff hobbymatic 939 The instruction manual I got with the machine is for a hobbymatic 947 and it looks exactly so I'm guessing the zipper foot would be the same. where...
You should be able to buy another foot, but you'll need to know if it is a high shank or a clip on style. Try this link to www.sewingpartsonline.com http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx they have two invisible zipper feet and two clip on ones. Don't mention your model but you should be able to email and ask if you aren't sure. I'd expect that the feet would be interchangeable between the models in the same era as yours. Just ignore the long funny shaped feet, they are for Pfaff sergers.
Oct 07, 2011 | PfaFF Creative 7570
I need a zipper foot
Go to any sewing machine store and buy a LOW SHANK adjustable zipper foot.This foot will screw on and fits almost everything. Yes, it's an older machine but you can still get most parts for it. Especially feet.I think this machine has snap on feet, so If you want an original foot take the ankle with you when you go to the shop to buy it.
sewman7
May 15, 2009 | Singer 7462 Mechanical Sewing Machine
Janome Harmony 2039 Mechanical Sewing Machine Logo
1,601 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
