SOURCE: remote control
I had the same problem. The problem is strange and seems to be with the receiver in the TV and not the remote control. The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV. This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote.
- Press and hold the red (ON/OFF) button for at least 1 min.
- Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
SOURCE: My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
SOURCE: Trying to program AVEiS tv model # a323lt to xbox
2971,2981,0938,2944 are the codes to check. google.com/+GopakumarGopalan
