SOURCE: my machine wont drain and the door wont open. I
Make sure that you have power to you machine by plugging a light into the wall oulet. If there isn't any power, go to your circuit breaker box and look for the breaker that supplies that oulet. If everything is good there, it probably is going to be a service charge to get someone to look at the unit since it is more complicated than you want to get into.
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
SOURCE: After washing several bath mats,
Hi If the drain pump filter assembly located inside the lower
front access panel is already cleaned then the issue is with the drain pump
motor assembly that is bad and should be replaced. Hope this helps...please
post back for further assistance. Daniel
SOURCE: The washing machine goes through
Hi The issue is with the drain pump that is clogged/kinked, as
it won't drain the water the door won't unlock. If this is a front load washer
then take the lower access panel out and clean the drain pump assembly. Hope
this helps...please post back with its complete model no for further assistance. Daniel
SOURCE: my washing machine is not draining properly, and
Hi
This issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Hope this helps...
Please post back for any further assistance.
Daniel
