Hi Michelle,
You need to preheat a heavy gauge baking tray first and then cook the pizza using the main element only. Also experiment with the position in the oven (eg. high or low).
Check to make sure you haven't inadvertently set the oven to expect temperatures in centigrade (celsius). Otherwise you probably have a bad bake heating element, or else a bad controller.
Get yourself an oven thermometer they are available for a few dollars at most homeware places, put in in the oven and you will be able to get your temperatures easily.
Good Morning kJordan!
FixYourBoard can likely help you with your unit. They'd remanufacture your part in 1-2 days, fully test the unit.. and back their work with a 2 year warranty. http://www.fixyourboard.com
Hi There I have found some stuff for you to read and hope this will help you get you in the right direction.let me know how this goes. It won't bakeUsually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.It bakes poorlyHere are two instances of when food "bakes poorly:"When
the food you're baking is done on top but not on the bottom--or when
baking just takes far too long to finish--the bake element may be
burned out. You
may get fooled into thinking it's working, because the oven is hot
inside. But many electric ovens use the broil element, too, during the
preheat and bake cycles. So the food may be getting heated only by the
broil element, which causes poor baking results. If
the bake element is burned out, replacing it should solve the problem.
Otherwise, you need to further troubleshoot the oven's electrical
system to locate the defective wire or component.When
the temperature is consistent but too high or too low, it could be one
of several different things. First check to see if the thermostat
sensing bulb has come loose from its holder. It could be lying on the
floor of the oven or resting on the heating element. This would cause
the oven to not heat correctly.If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic
ovens with a digital display use a sensor to monitor oven temperature.
To solve temperature problems for these models, you may need to replace
the sensor. On some digital-display models, you can calibrate the
temperature using the key pad. See your operator's manual for details. Ovens
without a digital display often use a mechanical system for controlling
temperature. On many of these units, you can remove the thermostat knob
and adjust the knob itself to more accurately represent the actual
setting of the thermostat. If,
when you remove the knob, there's a screw on the back of it with a
small calibration plate, you can loosen the screw, adjust the plate,
then tighten the screw again. If the knob isn't adjustable, and the
oven temperature is off by more than 30 to 40 degrees, you need to
replace the thermostat to solve the problem.
Thank you for writing to fix ya. Best Regards Richard
Hi There I have found some stuff for you to read and hope this will help. Let me know how it goes. It won't bakeUsually,
burned out. You
replace the thermostat to solve the problem. Best Regards Richard
Not familiar with this particular range oven but the thermostat should look like a longinsh cylindrical closed end metalic tube. You may have to raise up the cooking surface to run the wires for a new thermostat. If your oven is cooking to high or too low you can try taking the bake temp control off the know and see if there is a fine adjustement for temperature. I use a temp probe with a very inexpensive Sears DVM (about 20 bucks at Sears) to adjust mine. You should give the oven a good 1/2 hour to heat up and another 1/2 hour between each adjustment. Remember, the oven temp will swing high and low to maintain the set temp. Hope this helps!
If oven does not heat check heating element and oven control. Follow also suggestion below: "
It won't bake
Usually,
It bakes poorly
When
burned out.
You may get fooled into thinking it's
working, because the oven is hot inside. But many electric ovens use
the broil element, too, during the preheat and bake cycles. So the food
may be getting heated only by the broil element, which causes poor
baking results.
If the bake element is burned out, replacing
it should solve the problem. Otherwise, you need to further
troubleshoot the oven's electrical system to locate the defective wire
or component.
When the temperature is consistent but too
high or too low, it could be one of several different things. First
check to see if the thermostat sensing bulb has come loose from its
holder. It could be lying on the floor of the oven or resting on the
heating element. This would cause the oven to not heat correctly.
Electronic
Ovens
If, when you remove the knob,
there's a screw on the back of it with a small calibration plate, you
can loosen the screw, adjust the plate, then tighten the screw again.
If the knob isn't adjustable, and the oven temperature is off by more
than 30 to 40 degrees, you need to replace the thermostat to solve the
problem.
