Computers & Internet Logo
A
Antonio Posted on Apr 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ACPI\ASD0001\2&DABA3FF&1 ACPI\ASD0001\2&DABA3FF&1
Axiom Media Support
Level 3:
Master:
  • Master 409 Answers
  • Posted on Apr 21, 2014
Axiom Media Support
Master
Level 3:
Master:
Answers
409
Questions
0
Helped
116179
Points
1269
That is the "Quick Launch Buttons" driver.
Check the HP Support site for your exact Model and download it.
if that fails, see if the solutions on this page work.
Unknown device ACPI HPQ0006 2 DABA3FF 1 HP Enterprise Business Community
E Williams
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 17, 2014
E Williams
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15673
Points
LENOVO G505
Error Message Unknown Driver = ACPI\ASD0001\2&DABA3FF&1
My Problem was when I installed Windows 8.1 the system took all the generic drivers and the correct video driver was missing. I had to install 2 drivers.
1) EnergyManager http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g505-notebook/downloads/DS037820manage
2) Video Driver
1helpful
Code-28 driver acpi compliant system
right click on the driver with error and uninstall it. Restart your computer to install the generic drivers. Usually, computers generate their own generic drivers for the hardware parts in your computer. After doing that, update all drivers. You can find the updates in the website of the manufacturer. However, if you would like to get the correct drivers in no time then you can use RadarSync.
David
When I shut down my HP Pavillion dv 5 1233 se, the power light contunues to blink. How can I fix this?
To reinstall power management in windows Vista operating system: 1) Click on start and type device manager in search field. 2) Click on device manager in the list. 3) Click + next to system devices. 4) Right click on folowing controllers and select un install one by one. Uninstall only the options that are available in the notebook from the following options. a) ACPI Fan b) ACPI Fixed feature button c) ACPI Thermal Zone d) ACPI compliant system Restart your notebook after uninstalling all above controllers from device manager. Operating system will install new drivers automatically on restarting notebook.Then need to install the latest BIOS for your notebook model to get rid of the issue.
Hello, i've got a problem acpi windows seven ms8137c+
Is this Mother board Windows & compatible?
Check at the Microsoft knowledge base and see if *********** board meets the specifications.
this board according to the specifications may not be compatible with Windows &
Windows 7 Requires at 2GB of ram.
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
1helpful
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
24helpful
3answers
Microsoft ACPI-Compliant Embedded Controller driver
Microsoft downloads and type in Microsoft ACPI-Compliant Embedded Controller driver or IBM Lenuvo site for this driver.
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
I need to disable tha acpi on an acer travelmate 529tx but i don't know how to do it. i am trying to install xp after a failure. i get bsod and says to press f7 when i install storage drivers but i need a...
I have seen on many forums that ACPI makes a lot of troubles to a lot of users under Windows. I will try to explain several things about ACPI and I hope that you will be able to solve your problems after you read this article. I cover only most encountered issues, but always there is a choice even if it's called ACPI disable.:)
The computer ACPI support is detected in the setup stage, but there are less frequent cases when ACPI is not detected and the Standard PC HAL is installed. If you want to force the installation of the ACPI HAL:
1. At the blue screen of the Windows XP setup when it prompts you to press F6 for additional mass storage devices press F5 and you will have a list of options.
2. Choose the proper HAL for your machine remembering that there are also different HALs for multiprocessor machines.
3. Complete the setup, go to Setup / Control Panel / System / Hardware / Device Manager / Computer. If you have listed the Advanced configuration and Power Management (ACPI) the process was completed successfully.
Warning: You can do the same thing if you don't want to install ACPI and your BIOS doesn't support ACPI disable setting. Just choose the Standard Computer HAL from the list of options.
Another method to disable ACPI is:
  • wait for the text-phase of XP setup to complete
  • before XP Setup Wizard to load, boot into DOS and change ACPIEnable = 0 from ACPIEnable = 1 in file c:\txtsetup.sif
The reason why ACPI is not installed on a computer with known ACPI compatibility may be a Microsoft known subtle incompatibility which can lead to hardware instability. In the installation step Windows XP checks the BIOS compatibility with ACPI and the BIOS presence on a known bad list. If the BIOS is there ACPI is not installed. Of course than errors can occur so you can force the ACPI installation (not recommended).
Try disabling it in the BIOS first, this can not be done on a computer with the operating system already installed as it will cause the machine to stop. MUST be done when you initially install the OPERATING SYSTEM.
Regards.
2helpful
5answers
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
ACPI error message
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
