Polaroid PoGo Digital Photo Printer Logo
Kell Posted on Apr 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer Buzzing and not printing
My pogo printer is buzzing when I put paper in. It does not feed paper out or print when images are sent to it. The printer receives picture data as indicated by the green light.
DJ CRO
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Apr 18, 2014
DJ CRO
Expert
Level 2:
Sergeant:
Answers
181
Questions
Helped
32171
Points
546
Hello. It sounds like the printer head needs to be changed.
5 Related Answers
Anonymous
  • Posted on Aug 26, 2009
SOURCE: How do you print pictures from your pc to the pogo
firstly you need to pair the printer with your pc
then right-click on the image you would like to print, then select 'send to' Bluetooth Device/ Bluetooth Other and the image should print
It might ask for the code the first time, after which the image should print
Anonymous
  • 7 Answers
  • Posted on Mar 11, 2010
SOURCE: Pogo images not appearing paper comes white
Be shure that the part to be printed is facing you and the "polaroid" logo is facing down
Anonymous
  • 319 Answers
  • Posted on Aug 02, 2010
SOURCE: Polaroid Pogo printer Mod
www.polaroid.com/.../_/CZA-10011%3A_Polaroid_PoGo%26%238482%3B_Instant_Mobile_Printer
Anonymous
  • Posted on Jan 01, 2011
SOURCE: wont print from digital camera
Look in your camera settings and change the connection from USB to Pictbridge. If that's possible then you should be able to connect.
Leon Robinson
  • 747 Answers
  • Posted on Feb 06, 2011
SOURCE: The pictures are not coming of the printer. What
the shiny is face down in printer.
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
When I am printing, there is a loud noise. Like something is not rotating correctly. Everything prints good, but that noise is really loud. It seems to happen when it feeds paper.
Hello there,
If there is a loud and buzzing noise inside it, the encoder strip, or the one that guides teh cartridge must be dirty. this causes buzzing sounds and mis alignment.
another is the rollers having too much paper residue in it.
i would recommend for you to clean the rollers with a lint free cloth and some water (just to dampen it)
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
1helpful
Brother printer will not print because I keep getting manual feed
thios means the job you sent to print was detected as a differant size then the paper in the tray.
you would have to put a page in the front slot of the machine until it clears out this job
2helpful
2answers
10helpful
2answers
Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
4helpful
2answers
What does load mpf mean
It does stand for Manual Paper Feed.
On this printer, that's on the front of the unit, above the paper trays.
Once your PC has sent a print job with the paper-select set to "Manual Paper Feed" the printer will not do anything until it's processed this job.
The easiest way to do this is to put paper into the MPF and let it print, but at some point you're going to want to fix your PC so it doesn't send MPF print jobs anymore.
To do this, open your Printer Properties and select the default paper tray instead of the Manual Feed.
3helpful
My polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
3helpful
Bought today..does battery have to be charged for 3 hours before use? please advise
first of all make sure that the pogo it turned off insert the paper from the packet with the blue peice on the bottom with the barcode facing down. and the paper facing shiny side up and logo face down. when you turn the pogo on the blue paper will feed through first then the printer is all setup and aligned ready to print via bluetooth or via USB cable. hope this helps
Printer feeds the paper out but won't print
there could be a lot of files that was sent to be printed, all other files were corrupted thats why it is printing continously without any image at all.
pls cancell all doc in your PC and restart the printer again
hope this helps
Top Polaroid Office Equipment & Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
