A diode is an electronic component that
readily passes current in one direction only and blocks the flow of
current in the opposing direction. If your microwave's diode has become
defective, your microwave will not heat and you will hear a buzzing
noise. Test the diode to determine if this is the cause of your problem.
Replace it if it is defective.
A capacitor is an electrical device
which stores electricity. A defective capacitor may be why your
microwave is not heating but you are hearing a buzzing or humming noise.
The capacitor will have to be tested to determine if this is the cause
of your problem. A defective capacitor will have to be replaced before
your microwave will work again. Make sure you discharge the capacitor before you test it, though.
A defective magnetron is the third
possible cause of why your microwave is not heating, but you can hear a
buzzing noise. Test your microwave's magnetron. Replace it if it is
defective.
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
Power Diode
A diode is an electronic component that readily
passes current in one direction only and blocks the flow of current in
the opposing direction. If your microwave's diode has become defective,
your microwave will not heat and you will hear a buzzing noise. Test the
diode to determine if this is the cause of your problem. Replace it if
it is defective.
A capacitor is an electrical device which stores
electricity. A defective capacitor may be why your microwave is not
heating but you are hearing a buzzing or humming noise. The capacitor
will have to be tested to determine if this is the cause of your
problem. A defective capacitor will have to be replaced before your
A defective magnetron is the third possible cause of
why your microwave is not heating, but you can hear a buzzing noise.
Test your microwave's magnetron. Replace it if it is defective.
