SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
SOURCE: Epson TM-U220PD
Necesitas colocarse para los productos de la ?POS? en el Web page siguiente: https://www.epson-pos.com/cgi-bin/sdssm/main/td_login.jsp?sel_lang=es
SOURCE: EPSON DRIVER TMU220 PD
It will be the advance printer driver v 3.10, Make sure that you do a selftest on the printer by turning it off and holding down the fedd button while turning it on/ It will print the internal setting of the printer that you need to set on the driver installation.
You need to click on printer port setting after clicking on the right printer module and choose you connection bac\sed on the self test and all the settings for it.
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
SOURCE: Epson TM-U220 Receipt Printer M188D Drivers
The driver for Epson printer has been
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
Warm regards,
Anirban Mazumdar
