SOURCE: BAD TRACK FOR EVERY SONG
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
SOURCE: whas the best way to delete songs off the Sansa 250e? ie. "bad tracks"
The songs are in the wrong format or have expired licenses
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
SOURCE: deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
