The directions to set the date and time on the Uniden EXS9500 are shown in the manual starting on page 21. Press and hold the Clock button (the second button from the left below the answering system buttons) on the base until you hear a beep. Use the Skip/Repeat buttons (the two end buttons of the answering system buttons) to select the current day of the week. The LCD with show 0 through 6 and the voice prompt will list the day of the week. Press Clock when the correct day of the week is announced. Use the Skip/Repeat buttons to select the current hour (1-12). Press Clock to set the hour. Use the Skip/Repeat buttons to select the current minutes and press Clock to save the setting. Use the Skip/Repeat buttons to select AM/PM and press Clock to save the current time and exit the clock setting menu.
Press
"Feature" "#" "*" and enter your password
(default is "########").
Press
"Show" and "0814"
Press
"Save" and then "Show".
The
option to change the year appears. Press "Next" to skip. To
change, press "Chg" then enter 2 digits for the year and then
"Save" and "Next.
The
option to change the month appears. Press "Next" to skip. To
change, press "Chg" then enter 2 digits for the month and then
"Save" and "Next.
The
option to change the day appears. Press "Next" to skip. To
change, press "Chg" then enter 2 digits for the date and then
"Save" and "Next.
The
option to change the weekday appears. Press "Next" to skip. To
change, press "Chg" until you see the day you want. Press
"Save" and "Next.
The
option to change the hour appears. Press "Next" to skip. To
change, press "Chg" then enter 2 digits for the hour in military
format and then "Save" and "Next.
The
option to change the minutes appears. Press "Next" to skip. To
change, press "Chg" then enter 2 digits for the minutes and then
"Save".
Press the "On/Off" button to exit the
programming mode.
What you are hearing during the day must be what is called "skip". Skip is active during the day where you will hear radio operators from hundreds of miles away. Their signal is bouncing off an atmospheric layer well aboe the earth's surface. At night this atmospheric layer degrades and then so does the skip. Unless there is someone close to your vicinity transmitting on the channel you are listening too, you will not hear much at all. Try changing the channels until you pick up a conversation.
Press and hold CLOCK until the message window displays C, and the default day is announced. To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced. Press CLOCK. The current hour setting is announced. The correct day setting is saved. To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced. Press CLOCK. The current minute setting is announced. The correct hour setting is saved. To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced. Press CLOCK. The current year setting is announced. The correct minute setting is saved. To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced. Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
1. Turn on the system. Hold down SKIP/TIME SET/CHECK. The system sounds a tone after 1 second.
2. While holding down SKIP/TIME SET/CHECK, press REPEAT/ANNC/ DAY. The system announces "Monday" and &'?appears on the display. Repeatedly press REPEAT/ ANNC/DAY until you hear or see the correct day.
3. While holding down SKIP/TIME SET/CHECK, press MEMO/2 WAY/ HOUR. The system announces "1 AM". &' appears on the display. Repeatedly press MEMO/2 WAY/ HOUR until you hear or see the correct hour.
4. While holding down SKIP/TIME SET/CHECK, press PLAY/PAUSE/ MIN. The system announces "01". &' appears on the display. Repeatedly press or hold down PLAY/PAUSE/MIN until you hear or see the correct minute.
5. Release SKIP/TIME SET/CHECK. The system announces the day and time you set.
6. To hear the current day and time, press SKIP/TIME SET/CHECK while the system is on or off.
1. Press menu once and answering machine announces "Time" and current time. The answering machine displays (1) through (7) indicating the day of week.
2. Press skip/ff or repeat/rew to until correct day is announced.
3.Press set/ringer to select the day.
4 press skip/ff or repeat/rew until correct hour from 1 to 12 is heard.
5. Press set/ringer to select the minute/
6. press skip/ff or repeat/rew until correct minute from is announced.
7. Press to set/ringer to select the minute.
8. Press skip/ff or repeat/rew for A.M. or P.M.
9. Press set/ringer to store your am or pm selection.
Thats all it takes so you shouldn't have any more problems like that, but if you do I will be glad to help.
Press "Feature" "#" "*" and enter your password (default is "########").
Press "Show" and "0814"
Press "Save" and then "Show".
The option to change the year appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the year and then "Save" and "Next.
The option to change the month appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the month and then "Save" and "Next.
The option to change the day appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the date and then "Save" and "Next.
The option to change the weekday appears. Press "Next" to skip. To change, press "Chg" until you see the day you want. Press "Save" and "Next.
The option to change the hour appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the hour in military format and then "Save" and "Next.
The option to change the minutes appears. Press "Next" to skip. To change, press "Chg" then enter 2 digits for the minutes and then "Save".
Press the "On/Off" button to exit the programming mode.
To change the answer message, hold ans on/off then HOLD the skip back button, don't let go until you finish the message, to change the amount of calls untill it plays the answer machine hold skip forward button till it says how many the press the forward button till you are happy, to change date and time, hold stop, it will say the day to change press skip forward, then press stop again, it will say the hour, press skip forward, then stop the minute, then skip forward, then stop again to confirm, i belive it is in 24hour time as well, when changing the time, but not on playback.
Set the clock You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced. 2. To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced. 3. Press CLOCK. The current hour setting is announced. The correct day setting is saved. 4. To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced. 5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved. 6. To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced. 7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved. 8. To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced. 9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved. To check the clock, press CLOCK.
You’ll need to set the clock so that it can announce the day and time that each message is received. Press "Play/Stop" to exit Setting the Clock at any time. 1 Press and hold "Clock" until the Message Window displays C, and the default day is announced. 2 To change the day setting, hold down "Memo/Repeat" or "ANNC/SKIP" until the correct day is announced. Then release the button. 3 Press and release "Clock". The current hour setting is announced. 4 To change the hour setting, hold down "Memo/Repeat"or "ANNC/SKIP" until the correct hour is announced. Then release the button. 5 Press and release "CLOCK". The current minutes setting is announced. 6 To change the minutes setting, hold down "Memo/Repeat" or "ANNC/SKIP" until the correct minutes setting is announced. Then release the button. 7 Press and release "CLOCK". The new day and time are announced. To check the clock, press and release "Clock".
