According to the specs I have Serena, the eMachines eTower 633i Desktop PC, uses a TriGem Cognac motherboard.
[TriGem is the manufacturer, Cognac is the model.
Note it is Not the TriGem Cognac+ ]
http://www.motherboards.org/mobot/motherboards_d/Trigem/Cognac/Specifications. (You can click on the photo to enlarge)
PDF motherboard manual,
http://www.elhvb.com/mboards/TriGem/manuals/index.htmlClick on - Cognac - in the left side of the list.
Going back to the Motherboards.org page;
(Nothing like upside down photo information, and the motherboard is turned 90 degrees to the Right, to how it actually sits in your computer case )
The processor socket is a Socket 370,
http://en.wikipedia.org/wiki/Socket_370Used for Intel Pentium III processors, and intel 'Celey' processors.
(Excuse me......Celeron.
An Intel Pentium III processor has TWICE the L2 cache, that a comparable Intel Celeron has.
The cache for a Processor is a small memory area for the Processor.
It is the First memory the Processor accesses.
The Ram Memory is second, and the Harddrive is third.
More cache for a Processor makes it more faster )
The motherboard chipset is an Intel 810.
The Northbridge chip of the motherboard chipset, is an Intel 82810.
The Southbridge chip is an Intel 82801AA, or an Intel 82801AB.
(Intel ICH, or Intel ICH0 )
Looking at the chart, and reading across, you can see what the Intel 810 motherboard chipset supports;
1) Processors: Intel Celeron, or Intel Pentium II, or Intel Pentium III.
2) Processor Front Side Bus: (FSB) 66MegaHertz, or 100MHz.
3) SDR Sdram ram memory at 100Megahertz.
[Single Data Rate Sdram is often just referred to as Sdram.
Erroneous.
Double Data Rate Sdram is also Sdram (DDR Sdram)
Synchronous Dynamic Random Access Memory
So is DDR2 Sdram, and DDR3 Sdram ]
Also referred to as PC100.
So when looking for a CPU you look for;
1) Fits in a Socket 370 processor socket.
Yep. The best is going to be an Intel Pentium III.
2) Has a FSB of 100MHz.
Hmmm,............
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_III_microprocessors#.22Coppermine.22_.28180_nm.29Scroll down.
Pentium III 1100.
Maximum frequency rate ('Speed') is 1.1GHz (1100MHz)
Front Side Bus = 100MHz
Uses a Socket 370 processor socket.
Part Number = RB80526PY005256
sSpec Number = SL5QW
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Coppermine%29.htmlhttp://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201100%20-%20RB80526PY005256%20%28BX80526F1100256%29.htmlIn the top header -
Specifications / Pictures (1) / CPU ID (1) / Comments (1),
click on Pictures (1)
You can click on the photo to enlarge.
256MegaByte of L2 cache. (256MB)
A comparable Celeron would have 128MB of L2 cache.
http://www.recycledgoods.com/products/Intel-SL5QW-PIII-Processor-1100-256-100-1.75V.htmlhttp://www.impactcomputers.com/sl5qw.html[ Don't forget to follow Anti-Static Precautions.
Clean the bottom of the Heatsink THOROUGHLY, and the top of the Processor if it needs it. (I always do anyway)
PROPERLY apply fresh, new Thermal Paste.
For additional questions please post in a Comment.
Regards,
joecoolvette
Thank you for your full assistance
i want to connect smps , but on my mother board there is both type of power connecter, which should i use
I have Intel 810e mother board and looking for buying new HDD 160 GB or 320 GB and prefer Seagate rater than Western Digital. Could any body guide me that will 160 GB or 320 GB and type of HDD like SATA or ATA or Baracuda or any other type of hard disk will be supported for Intel 810e mother board.
Waiting for your reply.
Regards
Tarun Bohra
Bangalore, India
[email protected]
I have intel 810e mother board. Does it supports Seagate 180gb or seagate 360gb or Western Digital 180gb or 360gb. Does it supports SATA or ATA or Baracuda or any other type of Hard Disk Technology.
I am looking for buy new hard drive for my Intel P3 733 Mhz with intel 810e mother board and other system Intel P3 1.4 Ghz system.
Waiting for your response.
Regards
Tarun Bohra
[email protected]
Please describe the specifics of your problem below. We'll add
your post as a comment to Hanve's Is Hard Disk is Upgradable for Intel 810 E Chipset motherboard with P III Processor problem, and notify you when a new solution is offered.
I have same problem intel 810e motherboard with 40gb hdd, i want to upgrade to 80gb hdd, please suggest.
i have 810E mother board with 40 gb harddisk. i trying to upgrade 80 GB segate hard disk, it got hang with installtion of windows 98, 2K, XP setup.
But when this hdd connect to 915 MB it get install
i hve problem occured in the USB port. to connect the USB device.
please give to the faithful solution. On this mother board
USB pins has shown on it.
need to upgrade hdd to 160GB on 810E motherboard is it supported or not
i want to upgrade my hard disk capacity from 4.3gb to 40 gb is it possible on hp brio ba400 desktop
