Are you referring to the orange light on the freezer is not
working or the freezer itself is not running? May I have the model number? The
serial tag, which lists your model number, is typically located inside the
cabinet, on the left side wall. With this information I can better address the
issue at hand.
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Check the fan blade. It sounds like it is rubbing. Usually they will rub the shroud and can be easily fixed by simply bending the shroud slightly. Hope this helps. Good luck.
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
