I do not remember how to set date and time on fuji digital camera/ F470
SOURCE: Fuji finepic F470 - Damage Ribbon cable for menu controls
Broken ribbon cable cause key pad not functioning, you may need contact and order a key unit from fujifilm spare parts and replace it to solve the problem.
SOURCE: How can I set my Fuji FinePix S700 to print the date and time on the picture?
FIRST , go to MENU of camera and look for SETTINGS , DATE & TIME , if you dont see this option then refer to the camera manual to see if you have this option, some camras have this feature and some of them dont , hope this helps AJ
SOURCE: Problem with F470 Fine pix camera
sounds like the keypad ribbon has either popped out of it's socket or, and this would be the common fault, the ribbon has broken. In which case fuji will be your only way to fix and get it serviced at the same time. last quote I recieved was £80.
source a donor camera on ebay for the cheaper option
SOURCE: Read error
Try formatting the card in the camera using the setting in the camera's menu.
Some makes of xd or sd cards do not work correctly in fuji camera's. Sometimes even formatting them in the camera does not have any effect.
SOURCE: Why do I lose date/time
You lose the date/time because the camera has no power to it to keep the settings. Basically don't leave the batteries out if you want it to keep the date/time. On the other hand it will just sit and run the batteries down just sitting there off. It is a bit annoying but that's why. Most cameras store an internal charge so they can keep the date/time but it is not supposed to last very long, it was designed so you could swap out dead batteries without having to reset the time/date every time. If it is happening on simple battery changes it means something may be wrong with the camera.
Testimonial: "That information was as I suspected I shall have to get a power lead."
