2002 Honda Accord Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ERG valve located on a 2002 Honda Accord ex 3.0 vtec
Where is the ERG valve located on a 2002 Honda Accord EX 3.0 VTEC engine?
  • Anonymous Mar 25, 2014
    f23a non-vtec
    Scanner says Vtec control system, is it ok to drive?
Anonymous
Level 2:
Sergeant:
  • Expert 299 Answers
  • Posted on Jun 18, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
299
Questions
0
Helped
139076
Points
911
Right beloww throttle body toward front of car
Whats the name of the wiring harness thats needed in a swap from non vtec to vtec
92-00 Honda Engine Swap Wiring Guide VTEC AND NON ...
honda-tech.com/.../92-00-honda-engine-swap-wiring-guide-vtec-non-vt...
Oct 8, 2011 - 92-00 Swap Wiring Guide for VTEC and Non-VTEC ... try to compile one thread that would try to answer pretty much 95% of all questions ... I wanted to do this because often times I end up posting the same thing to ... to ECU harness so using an EX/SI 92-95 engine harness will make VTEC plug and play.
97 accord non VTEC to VTEC ' HondaSwap
hondaswap.com > Model Specific > Accord
Jan 16, 2010 - 15 posts - ‎6 authors The distributors may be different on the vtec/non vtec. .... As was previously stated, allyou need to do is add wiring for VTEC. ... that connect to the ecu to the connectorsthat wire in your engine harness while the engine is out... f22b2 non vetec swap to f22b vtec need help asap
Sep 22, 2012
96 accord head swap non vtec to vtec
Jun 1, 2012
1990 USDM CRX Si D16A6 to ZC SOHC non-VTEC ...
Mar 7, 2012
99 Accord non-vtec to vtec engine swap, need help
Sep 27, 2011
More results from hondaswap.com
How to fix VTEC System Malfunction code P1259
It is the wire close to the VTEC valve solenoid plug be cut off. Sounds wired, but it happened to my 2001 accord EX V6 sedan. After I solder it back, the TCS light turned off. But I had to disconnect the battery for 5 minutes and put it back to reset the Check Engine light.
Abs light 0n on my 93 accord ex with a 96 jdm h22a dohc vtec
need to pull the ABS codes to see where the problems are.
9helpful
3answers
Code p1259
low oil level can cause this as well as a bad oil pressure switch for VTEC control, possible VTEC solenoid.
Another reason for this code is the immobilizer. the anti theft device that looks at your key for the diode to match the car. This is on cars with out the VTEC.
On the VTEC system
DEFINITION:
PROBABLE CAUSES:
-Low oil/pressure
-Blocked oil pressure
-Failed VCT oil control valve
I have a 2000 honda accord ex... My engine light is on and throwing the p1259 code. It is not a Vtec engine... help. I just got the oil changed and the light is still on. However they put 10w30 in.. should...
The P1259 : is problem in the VTEC Oil Pressure Switch circuit or VTEC Solenoid Valve circuit.
check the wire on the VTEC Oil Pressure if it's loose.
P1259code 98 honda accord ex
p1259 is vtec system fail. check your oil level and condition. will prob need a vtec sol and filter and poss the vtec pressure switch.
3helpful
Just got a P1259 code on my 98 honda accord
I have a 1998 Honda Accord EX. I had the check engine light come on as well and I had the code read by PepBoys. The code was:P1259 or VTEC SYSTEM Malfunction.
I Don't know jack about were to start to fix this problem, so I bit the bullet and took the car to my Honda Dealer. The problem was checked out and was told this.
( REPLACE VTEC VALVE ASSEMBLY)
I had them do the work because I dont know how to do this. So after $204.00 in Labor and $162.29 in parts, for a grand total $366.29, The car was fixed!!!!!!! Run's great and no check engine light on anymore. So to help you out as best I can, here is the numbers that are on my work sheet. I dont know witch numbers represent the part number but this is how it looks on my paper.
1 15810-PAA-A02 8108797-90870 VALVE ASSY, SPOOL $150.75
1 15825-P0A-015 8161598-15999 FILTER, SPOOL VALVE $11.54
There you go! I hope this gives everyone a place to start. maybe get your self a Haynes Repair Manual (#42014 is for the 1998-2002 Honda Accord, all models) and try to do the work your self. Good luck to all of you form Donald M. in SoCal.
1helpful
Connector for Speed Sensor on1996 Honda Accord Auto Trans.
If you are talking about just plugging into the speed sensor yes. A VTEC and NON-VTEC are one and the same.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
