Question about Konica Minolta BizHub C650 Copier
My colours do not align on my bizhub c650 - Konica Minolta BizHub C650 Copier
  • Konica Minolta Master
  • 6,850 Answers
Run the registration procedure. do you have any oil can showing on the bottom of the control panel P-21. P-28 etc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 30, 2015
2 Suggested Answers
SOURCE:
SOURCE: konika bizhub c650 not printing through network
pls can i join
Posted on Apr 20, 2010
Serial number need to be enterened KONICA C650
Notes:
1. When replacing the NVRAM or the EEPROM board, if the parts are replaced with used parts, the License Management error condition cannot be resolved by performing the repair operation.
In this scenario, Initialization would then be necessary and support must be contacted.
Additionally, if both the NVRAM and the EEPROM board are replaced, Initialization will be necessary.
IMPORTANT: Perform the Repair Procedure first, then the Initialize procedure. If initialization is required, collect the following information before calling support:
  • If i-Option was ever licensed on the MFP and if the additional 512MB of memory was ever installed at any time
  • The firmware level prior to the machine being upgraded to version 88 (bizhub C353 and bizhub C650 series models only)
  • If the machine ever had firmware version 85 or 86
  • A history of recent NVRAM or EEPROM board replacement
  • Obtain a machine Management List and have it ready to attach to the ticket.
  • A screenshot of the message returned from the LMS if "Repair" was unsuccessful
  • A "Request Code" from the MFP and the S/N must be obtained in order to start the "Initialization" procedure (see attached "Obtain Request Code" and "Initialize")
2. Make sure to enter the MFP Serial Number, Repair Demand Code and the Request Code in uppercase letters when entering data in License Management Server online.
3. Version 88 firmware refers to the bizhub C353 and bizhub C650 series models. Other models have the correct firmware from factory.
4. To view a PDF, you may need to download a free copy of Adobe Reader®.
Aug 19, 2017 | Konica Office Equipment & Supplies
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Jan 01, 2017 | Konica Minolta BizHub C650 Copier
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Erreur P21 konica C650
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Jun 08, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Bizhub C451/c550/c650 Toner...
Code erreur c3b04
what solution for the trouble code c-3B04 for c650
Apr 01, 2013 | Konica Minolta BizHub C650 Copier
Printing consecutive page numbers on multiple documents
look in applications (mainscreen) and I thinkit's under stamps/overlays. You might even be able to choose what page number to start with
Jan 06, 2009 | Office Equipment & Supplies
Konica Minolta BizHub C650 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
