We have a battery operated clock. both of the hands are loose, and the only way to tighten them is to remove the back of the clock mechanism because somebody has glued the cover to the face plate The mechanism box is also glued so replacing it we'd have to pry it off somehow. This clock is one of a kind and my husband is just crazy about this clock. so we need to remove the back of the little box on the back without snapping the box completely useless.
SOURCE: repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
