Press and hold MODE and then press PRESET 1 to turn on or off the clock display priority. This should allow you to set if the clock stays on while the unit is off.
Aside from this, you may need to double check your wiring, specifically the RED and BLUE wires. The RED needs to be connected to a switched source of power and not directly to your battery/etc. It needs to be a source that is only ON when you want it to be ON (such as the ignition on wire). The YELLOW wire is the only one that should be connected directly to your battery.
Double check the BLUE wire is connected correctly to your AMP as the AMP running all the time would kill a car battery overnight where-as the stereo clock display alone should take many days to kill a properly functioning car battery.
Most people do not realize that a laptop has 2 batteries... the normal 4-6-9 cell battery that we constantly recharge and a smaller (internal) battery to maintain CMOS memory where the clock and other data are stored.
The CMOS battery is normally inexpensive, typically you can find them in a good electronics store or even on ebay. They are easy to change as they typically have a quick disconnect plug. I am not sure where it is located on the ASUS, but look in the memory compartment or the hard drive compartment.
Don't think you can bypass this thing because the RTC (Real Time Clock) battery is, most likely, dead. But if you can replace the just the keyboard, then you'll still have a working computer. I'd leave the RTC battery alone and use software (such as Atomic Clock Sync) to set the date and time automatically every time the computer boots into Windows.
Some automatic breadmakers have a place for inserting batteries. The intent is to create a memory back-up for two things: 1: The digitally-displayed clock setting, and 2: Personalized program settings you save to the machine to perform again later. Now you're not required to install or replace the batteries in your breadmaker unless you desire these settings to be maintained long after the breadmaker is unplugged. And, if you do decide to install or replace the batteries be certain to use alkaline-grade or better. But be forewarned though: Breadmaker clocks don't adjust for DST (Daylight Saving Time) Hope this helps!
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Hi!
The internal battery is bad. It has to be replaced. Contact your local Sony service center, but
if they ask too much, you can contact me at [email protected]
and I will give you a good price.
I work in Sony service center.
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
