KitchenAid 32685 Mixer Logo
A
Anonymous Posted on Apr 16, 2014
KitchenAid mixer does not turn on - KitchenAid 32685 Mixer
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Mar 02, 2016
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583032
Points
2445
Check the motor carbon brushes, remove the back cover and check for broken or disconnected wires. Using a multi meter check the main cable for continuity from wall plug to the speed control board. That will be the black wire and the white wire at the bottom on one side of the control plate. After that check fields for continuity, that will be between the 2 wires on the bottom on the other side of the control plate and the brass insert inside the brush holders. One of the wires will be a circuit through the fields to one of the brush holders.
2 Related Answers
Anonymous
  • Posted on Dec 07, 2008
SOURCE: My KitchenAid Mixer won't turn on
Check your Brushes  or bushings or whatever there called ) those little black things on the side of your mixer above the speed selector and the up/down switch) Check to see if they have started to wear down then i recommend taking it in for service. Good Luck!
Anonymous
  • 1902 Answers
  • Posted on Jan 16, 2011
SOURCE: Kitchenaid Mixer stopped working checked power
Hello & Welcome to FixYa
I believe the motor is bad and needs replacement...Motor brushes goes bad after sometime and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Kevin
2answers
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Kitchenaid mixer shoulder
The mixer turns on but it is not turning. What's wrong please.
1helpful
Have a kitchenaid stand mixer Model # KP26N9XER the attachment hub is not turning correctly it only turns a liitle at a time with a thumping sound. Opened up looked at the gears and their are bits of metal...
Obtain a copy of the Repair Part List for your model from Kitchenaid.com
Download the Service Manual :
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It is not exactly for your model but you can learn a lot from it.
Open up your mixer. Get rid of all the grease. Replace the Worm Gear.
Use fresh Kitchenaid Food Grade Grease on all gears.
Caution: Do not use a screwdriver to pry out the Planetary Assembly.
2helpful
My kitchenaid mixer seems to have dropped down to low in the bowl
Tip the mixer up and look for a screw on the hinge underneath the top part. Turn this screw counterclockwise about 2 turns and the paddle will clear the bototm of the bowl.
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
1helpful
3answers
Are attachments for a KitchenAid K5 compatible with the K55?
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Kitchenaid mixer races when turned on
Hi. Get in touch with Kitchenaid Parts and order a new Control Board. If your mixer is still covered by warranty it's free. ricardok45
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
