SOURCE: Kodak Z740
If you replaced that batteries and it isn't staying on, it should be looked at a camera shop to find out why it isn't getting any power to it.
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. Before you pay
for expensive repairs that you may or may not need, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: Kdak MX1063 won't stay on...
Try cleaning the contacts from the battery and the battery compartment
of the camera. I had the same problem, used a cotton swab to clean and this fixed it, it seems to be
a common problem.
You can also try the official Kodak troubleshooter at:
SOURCE: Junk Kodak Z14854IS digital camera?
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
SOURCE: My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
