Kguard OT801-8CW134M All-in-One Video Surveillance System Logo
A
Anonymous Posted on Apr 16, 2014
Dvr re-starts when login in - Kguard OT801-8CW134M All-in-One Video Surveillance System
U-Spy Store DBA Pro Video Security
Level 2:
Habit-Forming:
  • Expert 106 Answers
  • Posted on May 17, 2016
Expert
Level 2:
Habit-Forming:
Answers
106
Questions
0
Helped
122462
Points
178
Sounds like a DVR issue. Probably a defect. Check if there is a firmware update. It may cure that.
2answers
I forgot the login password to my clarion view hd digital dvr. How do I reset the dvr login password or format the dvr
If it was just installed, ask the installer. Clarion devices have numerical model numbers. That is needed for the search query Charles.
https://www.google.com/search?q=clarion+view+hd+digital+dvr+reset
3helpful
My friend bought a Cobra 8 channel surveillance system, in trying to set it up, he can't get past the 'device number' for unit 63890. What or where is the 'device number'?
Connect DVR to network and login into DVR.
You will get all information in System info page.
if you forget DVR Password here is the Cobra Dvr video for you.
HOW TO RESET PASSWORD ON MIGHTY MULE CAMERA DVR? LOST THE ORIGINAL PW!
Login Once the DVR boots, the [POWER] indicator will show constant red. The default factory password is blank. After the DVR boots, press the [MENU] key on the front panel or right click the mouse. Choose "Login" interface as shown below:
Pic 2.2 user login
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Why can't I login to my DVR web interface?
If you on are the same network as the DVR, you should be using the DVR's IP. Usually a 192.168......., depending on your service or router (COMCAST, AT&T etc...)
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_101fbc448ddafa3d
3answers
Ipolis mobile app now says no more logins available
shutdown dvr. unplug it for 30 seconds and then re connect. should work fine
I FORGET LOGIN PASSWORD OF "ZEN TECH DVR 36584 V
i have the same
ZEN TECH DVR 36584 V u can remove the battery and turn on the dvr but i cant log in i fogot the default password ....anyone rem it?
217helpful
6answers
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Top Kguard Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Kguard Home Security Expert? Answer questions, earn points and help others
