Motorola Mobility H560 Bluetooth Headset Logo
A
Anonymous Posted on Apr 16, 2014
My h560 won't pair with my phone
It did ask me for my password, but i don't remember it
1helpful
Can not get my LG 835 flip phone to pair with my Motorola H560 head set.
Some headsets need to be set to pair mode to link with your phone. Check the instructions/user manual and if all else fails, try holding buttons on the headset and see if you can get a different reaction out of it.
If you get past that stage and require a code, try 0000, 1234, etc. The book should tell you
1helpful
I don't know the password to my synet7wid
if you remember the password and it doesnt work connect an external key board and check it with external keyboard if you dont know the password ask again
2answers
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
I changed phones and can not remember my password to install H560 blue tooth
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
1helpful
I have a Motorila H560 bluetooth ear piece and I
Use the passkey as "0000" or "1234". This will work for sure.
Lost my password
Bluetooth Motorola H560 was given as gift, but I don't know the password so it will pair with my Pantech phone. Where to get the password for it?
2helpful
The blue light will not shut off and the device will no longer connect to my cell phone. Motorola h560 hands free device
Hey Jennifer - might I recommend resetting the device completely and going through the pairing process again?
To do this, first turn the switch to "off" by sliding it back, toward the earpiece/speaker. Then press both volume buttons and the "call" button at the same time, holding it for about 10 seconds. That will reset it to "like new", and then you can re-pair the phone and device. If you need holp, you can check out the manual and instructions here:
http://www.motorola.com/support/v/index.jsp?vgnextoid=aee54c26f3f8f110VgnVCM1000008406b00aRCRD&vgnextchannel=248ae66506e9d110VgnVCM1000008406b00aRCRD
Deleted bluetooth out of phone
If you're talking about a headset pairing, the default password is usually 0000, or 1111.
If it is not a headset, let me know what you are trying to pair back up to your phone.
Please don't forget to rate.
3answers
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
