Can I hookup my D-link524 directly to my stereo receiver
SOURCE: I want to install an antenae hook-up wit sirius satelite radio
Hi, this one is easy as pie. tools you need,philips screwdriver and a small socket set. . sitting in drivers seat look down and to your left of the column, you will see a philips head, remove it, leave door open, now on the right hand side of column about the same location is another philips head, remove it. open ash tray and check for philips heads there, insert ignition key and turn it on, dont start it, step on brake and move the shifter down into 1st gear, now you should be able to remove this whole shroud by pulling on the edges gently but firmly you will hear little pops aas you move around the edge from the radio all acros s the driver dash. now with that out of the way, remove the 2 socket head screws holding the radio bracket(1 on each side of radio). then pull radio out removing the power connector and antenna connector. there you go, install in the reverse order to finish the interior.
SOURCE: my friend has a stereo
NOt all audio is borne strictly on HDMI.
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
