Scotsman C0630MR_HD30B-32 684 lb 30" Remote-Cooled Medium Cube Ic Logo
A
Anonymous Posted on Apr 15, 2014
Short freeze Code 8 short freeze cycle
Beto Flores
Level 2:
New Friend:
  • Expert 102 Answers
  • Posted on Dec 04, 2014
Beto Flores
Expert
Level 2:
New Friend:
Answers
102
Questions
0
Helped
64810
Points
165
HOW OLD THIS THIS MACHINE? IT COULD BE THE CONTINUITY SENSORS NEED TO BE DESCALED, DO YOU HAVE WATER RUNNING OUT THE DRAIN DURING ICE MAKING PROCESS TRY AND CLEAN PURGE VALVE OF ANY DEBIS, ICE SENSOR SHOULD BE 3/16 OR 7/32 AWAY FROM EVAP (GAP) ,ALSO GENERAL MAINTENCE IS VERY IMPORTANT FOR ICE MACHINES
howard thompson
Level 2:
Novelist:
Champion:
  • Scotsman Expert 373 Answers
  • Posted on Jul 17, 2014
howard thompson
Scotsman Expert
Level 2:
Novelist:
Champion:
Answers
373
Questions
Helped
249171
Points
454
Ice is to thin. Check to make sure water inlet valve is not letting water go through valve during freeze cycle. Make sure condenser coil is clean and condenser fan is running. Check the hot gas valve to make sure it is not bypassing during freeze cycle.
  • Beto Flores
    Beto Flores Dec 04, 2014
1helpful
Scotsman c0330 is not making ice and display code flashing 8
Low room temperature - Most Scotsman ice makers won't produce ice when the temperature is below 55 degrees Fahrenheit. Make sure the machine is in a room or setting that is warmer. ... Faulty thermistor - A bad thermistor usually causes the bin to fill with too much ice.
Diagnostic Codes
  • 1 - Long freeze time. Shutting down.
  • 1 (flashing) - Retrying long freeze cycle.
  • 2 - Long harvest time. Shutting down.
  • 2 (flashing) - Retrying long harvest cycle.
  • 3 - Water filling slowly.
  • 4 - High discharging temperature.
  • 5 - Failed sump temp sensor.
  • 7 - Failed discharge temp sensor.
  • 8 - Thin ice from short freeze cycle.
  • 8 (flashing) - Retrying short freeze cycle.
Code 8 blinking machine making very thin ice?
Short freeze, thine ice.
Cause: Grounded ice thickness sensor.
Solution: Check sensor for dirt and position. Clean and adjust gap to evaporator surface using 13/64" drill bit as a gauge, lay flat between evaporator plate and ice thickness probe and adjust 1/4 screw 1/8 of a turn clock wise at a time after every harvest cycle. You don't wont the ice any thicker than 13/64 or thinner either. If you are still having problem after cleaning probe then replace it but you will still have to adjust the probe.
Fault Code 8 Short Freeze
Likely cause.
1. Grounded ice thickness sensor.
Solution, check sensor for dirt and position. Clean and check gap to evaporator surface.
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
1helpful
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Emerson quiet cool cycles every 6 mins
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
1helpful
Unit compressor keep short cycling not feezing or
replace your compressor relay. that's what goes wrong 99% of the time
Goldstar Dehumidifier compressor short cycling...
If the coil is freezing up and the compressor is short cycling,there must be a low pressure switch opening, do to either, low on charge or not enough air across the coil.
Wont turn on
yes they tell you if there is something wrong
Beep Code Descriptions Document
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
Top Scotsman Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Sierra
Sierra
Level 1 Expert
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
