Exercise & Fitness Logo
A
Anonymous Posted on Apr 16, 2014
Life fitness 95Te - Life Fitness Exercise & Fitness
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Feb 16, 2012
SOURCE: I have a life fitness 95Te and can not reset the wax bag notification on screen. i'm told to hold the pause button then press the clear button. I don't have a CLEAR BUTTON!!
Dear Si:
Please go to the pag 48 from your user manual. If you do not have the user manual. go to the next web page: www.fitness.manualsonline.com and download for free, and follow the instruction for reset your wax bag device.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
What does activity zone keypad not detected mean
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control.
LifeFitness 95TE Treadmill Parts SPORTSMITH net
Activity zone keypad not detected
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control. LifeFitness 95TE Treadmill Parts SPORTSMITH net
How to access to life fitness treadmill 95te menu
Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
Heart rate Monitor not working on Life Fitness 95Ti Life Pulse
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
Repair Parts for LifeFitness 95T 95Ti 95Te Treadmills Midline SPORTSMITH...
1helpful
Dear Si:
ernesto cuadra
1helpful
The screen reads "Unit immobalized
Here is the manual for your unit. See the section on Managers Configuration specifically custom message on page 37.
http://jp.commercial.lifefitness.com/resources/content/4/9/7/3/documents/95Te%20Console%20User%20Manual.pdf
Hi, I have a Life Fitness Treadmill that says "Unit immobolized by manager". Could you please tell me how I can fix this? Thanks!
hi
press clear it
then when it comes on HOLD SPEED DOWN AND press PAUSE it clears up
call me 347 515 8670 if you can not do it
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
