Display screen is blank, but the oven works. Tried 'options' to reset clock but nothing displays. Beeps when dial turns.
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
SOURCE: GE Spacemaker Microwave Clock inop
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
SOURCE: oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
SOURCE: Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
SOURCE: GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE
We're
