Koolertron For 2003 2004 2005 2006 2007 2008 Renault Megane Indash Car DVD Player GPS Navigation Systems AV Receiver with 7 Inch Digital HD Touchscreen and iPod SWC Factory FitFree Map Logo
A
Anonymous Posted on Dec 03, 2017
Koolertron dvd central
Hi, I bought this dvd central and the rear view reversa camera isn't working. The camera sends the signal. I checked by pluging the camera to the auxiliar in connector. The central does not show the imagem when reverse gear is engaged. Is there a configuration step other than the "on and off" switch in the setup menu?
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
What can I do to repair gps sd card to work ?
your going to have to send it in for repair no way or they going to let you fix it not with that error
View movies on pioneer avh-x4500bt when driving
I don't think it is a good idea for driving safety. But for the passenger in your car, they can do, and you can also try this:Koolertron 2.7" 1080P HD GS9000 Dash Cam Night Vision With GPS G-sensor
Milion D1308 radio no video signal from rear view camera
i have an million d1308 stereo in my 2000 f150 my brother gave it to me and forgot the passwords for it how can i reset them or find them out
Koolertron Mazda 3 ipod connection problems
common problem cause by the ipod screen turning off (going to sleep).
I bet it keeps going if you keep it active (awake).
No cheap fix sorry.
Koolertron 2011 sonata
Hi Robert,
Your questions should be sent to Koolertron directly. They will provide the most reliable answers you could possibly hope for. While Koolertron is located in China, they do offer support via email at: [email protected]. They offer phone support to - details on their support webpage.
2helpful
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
1helpful
1998 E230. power seats,central locking,power windows, turn signals, wipers, power mirrors all stopped working
hello,check your fuse number 4 ,15 for signal light ,check also the rear fuse box for power window,central lock,power seat ,located at rear seat in front of battery,ty
Won't display photos from a CDRW
Check what type of file type the Kodak is creating, it may not be a JPG. If its not you would need to look in settings or check the manual to see how to change the camera so it saves the files as JPEG'S.
Or the long route compress them into JPEG'S on your PC.
Top Koolertron Video Cameras Experts
 Mikey
Mikey
Tony Parsons
Tony Parsons
Are you a Koolertron Video Camera Expert? Answer questions, earn points and help others
