On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
We purchased this stroller second hand for our grandson. We cant figure out how to put the seat in the upright position. It is in the laying down position which was fine at first, however, now he sits up on his own and does not want to lay down.
Can someone please inform us as to how we can get the back of this seat to sit up? Thanks so much.
Cheryl
Should be a bar behind the seat that pulls up. maybe it is hidden by the cloth behind the seat? it is red and when pulled up will release the seat to recline.
Strollers with detachable infant car-seat carriers extremely practical. In the first couple of months, your baby can sit securely in the infant carrier while you go for a walk. As an added benefit, you can transfer your baby from the stroller to the car without having to disturb her, as you would with a pram. For older infants and even toddlers, you can use the stroller without the carrier. Most have seats where the back adjusts from nearly a full upright position to a full recline.
Stand in front of the Buzz chassis at the front wheel. On either side of the seat unit you have a grey button. Push the button down and now you recline the seat / sit it upright as required.
The steering handle has a red switch on it. Pull the switch to the right and then twist the handle grip forward. The stroller should start to collapse.
Infant seats sit rear facing. You'll have to recline the stroller seat. Then the clip on the infant seat will grab the food tray and lock it in. Your stroller might have come with an additional strap to secure the seat once you have it locked.
TO FOLD STROLLER • Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section. • The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame. CANOPY * The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23. SEATBACK POSITIONING * The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically. http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Viewed from behind, there are two cords with pull tbs that are gathered together in the center of the seatback with a black plastic gather. These two cords are loosen or tightened to raise or lower the seat back recline position.
I purchased my stroller from ebay and one side of one seat would not stay in place it would only stay in the fully reclined position. I took it to a maclaren autorized stoller repair store and it was $37.28 to fix one bracket.
