Lines are clear need help removing/cleaning carb
If there is a fuel bowl on the bottom of the carb with a center screw take it off and clean it make sure you have new fuel and filter and clean your air filter too
If this is a briggs and stratton they have a fuel pump on the front of the carb and ethanol plays havoc with the diaphrams in the fuel pump. I have to overhaul the fuel pump each year. Before you try anything else try "mechanic in a bottle" first. It is available at home depot, lowes, tractor supply etc. Just follow directions on the bottle and often it will clean out the varnish deposits in the pump and the carb both. Hope that helps.
