Sony VAIO VPCL214FXB 24Inch AllinOne Desktop Logo
Stacey Karliss Posted on Apr 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BEZEL SENSOR will not disable by touch
I am unable to disable the BEZEL SENSOR using the Touch method in User Guide. I am looking for another way to disable it.
shevantha perera
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 125 Answers
  • Posted on Apr 16, 2014
shevantha perera
Expert
Level 2:
New Friend:
Cheetah:
Answers
125
Questions
0
Helped
7451
Points
202
Try to change it from the BIOS
  • Anonymous Mar 23, 2016
    please tell me how
  • Pratik Manghwani
    Pratik Manghwani Mar 23, 2016
    please tell me
I am unable to disable-by-touch the BEZEL SENSOR of my Vaio VPCL 214FX/B, is there another way?
I don't think you are using the right terminology. That sony machine says nothing about a "bezel sensor" in it's user guide...
are you referring to the touchpad?
are you referring to touch screen?
The bezel is the inside angular portion of the housing for the screen, as show in the video below..
1helpful
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Unable to use touch pad....rt clk and slide key
If the laptop is that new, the problem is probably the touch pad "disable" button. Look for a small button just above or near the touch pad and make sure the touch pad is not turned off. If you cannot find the disable button, look in your user manual for the touch pad disable.
Unable to transfer to mp3 player
Based on Philips SA6045 User's Guide, youou can transfer your media content in the following ways:
  • Using Windows Media Player 10 – Note: You cannot transfer all video files using this method. It is recommended to use Media Converter for Philips to transfer video files.
  • Using Windows Media Player 11 - Note: You cannot transfer all video files using this method. It is recommended to use Media Converter for Philips to transfer video files.
  • Using Windows Explorer - Note: While all files will transfer, they may not play back if the player does not support the format.
It is recommended that you use Media Converter for Philips to transfer your video content, and Windows Media Player (10 or 11) to transfer your music and pictures to the device. Use Windows Media Player (10 or 11) to transfer all video that you purchased online to the device.
CLICK HERE To download Media Converter For Philips
for further assistant, please check the User's Guide,
CLICK HERE To see the User's Guide for Philips SA6045
good luck :)
60helpful
6answers
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . [email protected]
1helpful
2answers
Disable tpms
I don't know if there is a problem with your TPMS receiver (on dash board), or your TPMS sensor is disable (in four tire). If it's the receiver problem, You have to go to the dealer ship to solve the problem. If it's the sensor problem. You can go to the dealer ship to let them find which sensor or sensors are fault, And replace them by the new one then doing the reset process.
Hi there When plugging in a USB mouse will it? or rather is it suppose to automatically disable the touch pad on a HP 530? Sometimes when plugging in my USB the touch pad is still active and I would like...
look in the control panel in windows to see how the mouse & pointing devicesoptions are set. If that is a dead end goto HP's website or look into the users guide for more info
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
