Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
How to get to clock on rangemaster 110 dual - Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
SOURCE:
  • 3 Answers
SOURCE: rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Posted on Nov 24, 2008
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
SOURCE: rangemaster toledo 110
Hold down two left hand buttons together for a long time. that should do it.
Posted on May 31, 2009
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Posted on Mar 27, 2010
SOURCE: their was apower cut now the clock and fan oven
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Posted on May 09, 2010
I have just moved into a house with Leisure rangemaster 110 dual fuel, how do i change the time on the clock have pressed all knobs in various sequences, found the automatic, the timer but cannot move it...
http://www.rangemaster.co.uk/Siteimages/Site_311/Pdf/ProfessionalPlus110DFOct08.pdf
User manual.
When the clock is first connected, the display flashes ( 0.00) and (?) alternately. To set the time, turn and hold the Timer knob to the clock symbol (?) and at the same time turn the Adjusting knob left or right until the clock shows the time of day. Remember this is a 24-hour clock. Let go of the Timer knob and it will spring back to the vertical, oven manual setting.
It is on page 6 of manual
Mar 28, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How do i bypass the clock on my rangemaster 110 cooker
Have had trouble with our timer on our Rangemaster 110 so ordered a new timer only to be credited as it is no longer available. Dont realy want to buy a new cooker this side of christmas, any way of bypasing the timer ?
Nov 11, 2009 | Rangemaster 110 (Gas) Kitchen Range
The clock on my fridgidare oven is making a grinding noise. When the oven isn,t even being used. model # REG533MD-2
You have a failing clock motor. It "was" available as part of an entire clock assembly only, but the part has been discontinued.
Apr 28, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster 110
it is not at all obvious.
from memory, there are 2 screws on the lhs side of the plate which remove and the plate will then move sideways but may be difficult to shift
Nov 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster toledo 110
Oct 26, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
27 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
