Please explain how to reset and zero out the larger seconds hand in my cK chronograph. I bought this brand new watch yesterday and its larger seconds hand won't adjust at 12' but stays at 12:01. Your help will be highly appreciated.
SOURCE: Have an Invicta Lefty Quartz Chronograph. The
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
SOURCE: Invicta Sea Thunder Chronograph resets
Only thing I can suggest is you return it for a new watch. I had so many problems with my Invicta Pro Diver that I finaaly gave up and bought a Timex. Oh and the Timex keeps on tickin' for 1/3 the price.
SOURCE: the second hand on my invicta chronograph watch
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
