Question about Life Fitness Exercise & Fitness
Life fitness f3 treadmill powers off itself - Life Fitness Exercise & Fitness
SOURCE:
SOURCE: Replace Switch error message
It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
Posted on Jan 27, 2009
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
I have a life fitness treadmill and an error code came up it F3, Any suggestions
If you wish to get some details about treadmill error codes; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Nov 10, 2016 | Life Fitness Exercise & Fitness
F3 Basic problem. Console problem
yes, if the machine is still under warranty make the dealer come and fix the console. the only other thing it could be is a faulty electrical connection but it does not sound like it. The quality of the unit should be better!!! Hope this is helpful:) thx
Jul 24, 2010 | Life Fitness F3 Folding Treadmill with...
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
May 03, 2010 | Life Fitness F3 Folding Treadmill with...
On trying to start my Life Fitness F3 I have a console display message PUT BACK MAG. Please can you tell me what I nead to do to clear this message and get started? Thank you for your assistance
First, check and make sure the safety magnet is in the correct place. If not, place magnet. If it is, then the safety magnet sensor, sensor cable, or the console is messing up.
Mar 18, 2010 | Life Fitness F3 Folding Treadmill with...
Jan 25, 2009 | Life Fitness F3 Folding Treadmill with...
Exercise & Fitness Logo
22 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
