Have done everything to try to fix. Original error was b200 then i cleaned the heads, unplugged, turned on & off and now screen says 5000 and making a loud noise.
SOURCE: Canon PIXMA MP240 scanner problems (physicl, not digital)
when i load paper it feed cockeyed,,,when rollers start it appears to only fee on one side and crinkles paper ..turns sideways and stops feeding....Help !
SOURCE: i have a canon pixma ip 5000 printer and when I
Most probably grinding sound come from plastic gear, and need to observe what gear is this, replacement part mostly in assembly. From authorized printer supplier.
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
SOURCE: Error Code
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
