Toshiba 42H81 42" Rear Projection Television Logo
A
Anonymous Posted on Apr 14, 2014
The screen on my toshiba ct 90101 is very blurry and I'm not sure how to fix it can anyone help?
It is a very fuzzy and unclear picture. It is a large tv with a large back.
4 Related Answers
tlm931
T.l. Moore
  • 273 Answers
  • Posted on Jan 20, 2009
SOURCE: my toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Anonymous
  • 1214 Answers
  • Posted on Jan 31, 2009
SOURCE: Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Darren Vaughan
  • 25 Answers
  • Posted on Jan 26, 2010
SOURCE: I have a crack in my projector screen can i get a
have checked the net and you can get front screen replaced on any size projection tv try
email
[email protected]
Anonymous
  • Posted on Apr 11, 2010
SOURCE: Toshiba TV repair
I have a Toshiba HD LCD tV, model 37AV50U. the screen is black. I still get audio and can change the channels but the screen stays black. It doesn't even show the menu box. Is this something I can fix myself?
Ecco Flat Screen TV. Not showing clear picture?
It sounds like you need a new one, but
How do you fix a blurry flat screen TV?
How to Fix a Blurry TV
  1. Make sure your picture isn't stretched. Play with the settings of your TV to ensure that the picture you're seeing isn't being stretched. ...
  2. Mess with your TV's different sharpness and picture modes. ...
  3. Reduce the noise. ...
  4. Swap out your cables. ...
  5. Unplug. ...
  6. Move it around.
Nov 3, 2022
Troubleshoot a Fuzzy or Blurry Picture on Your TV
Apartment Therapy https://www.apartmenttherapy.com > troubleshoot-a-f...
Search for: How do you fix a blurry flat screen TV?
Fuzzy picture help 55" rear projection toshiba
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused trouble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is installation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
1helpful
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
1helpful
My Powershot 410's LCD screen suddenly went fuzzy,
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
I have a crack in my projector screen can i get a replacement screen? toshiba ct-90101
email
[email protected]
2helpful
2answers
Toshiba ct-90101 original
Here is the site for remote codes:
www.remotecodelist.com/remotes/
16helpful
7answers
Toshiba TV repair
1helpful
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Picture fuzzy
hi dear
sound like to me it's screen voltage too hi check some cap on CRT base value 1mf 200v or above.at the same time u can check the cap on horrizantel 2.2mf 250/300/450vot some wear .have good luk
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
