I have 42 inch plazma flat screen tv one day when i on my tv one white line appear horizental in the centre of the screen and then after one week 2 more line appears and after 8 or 9 days 2 more line appear what is the problem regards athar
SOURCE: philips ph9630 plasma 42 inch
did u do a hard reset first??
doing tat helps few people to get solved the problems
SOURCE: yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
SOURCE: 2 black lines on 42" philips flat tv
i can save you a trip to service center its not the x sus its your display or ribbons to display most likley display you can try to take off back and you will see ribbons on top or bottom of display try to gently press where screen is black if the screen fills in its connections on ribbons if not its your display cost prohibitve to repair sorry
SOURCE: nsWe have philips tv model
I also have the same model.Try reducing the brightness and contrast.It worked on my tv.
