The unit is in protector mode when it is power on even the speakers are disconnected with a normal room temprature
You unit is most likely has DC Offset(a damaged amplifier). Unless you are an audio specific technician, this repair is not a DIY. If you'd like more information, or would like to inquire about having your Sony repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
SOURCE: I need power and volume control codes only for my
Not sure if you have tried the 3 codes listed in the OCAP 4 universal remote manual for Sony Receivers
31759, 30158, 31758
Sony DVD players
20533, 21533, 20864, 21033, 21070, 21431, 21536
In addition I find a way of finding the codes at the Universal Remote support site
http://www.urcsupport.com/html.php?page_id=313
But it gives a generic code for Sony DVD systems
20533
Not sure if you have already tried all this. The other option might be to find if the Sony system remote has the code for the Charter cable modem.
SOURCE: push power protector
I brought the unit to an authorized Sony repair depot and they concluded that all the power transistors were fried. They replaced the system board under warranty (at no charge) and the system has functioned perfectly since. Thanks for your help. -Steve.
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
SOURCE: turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
SOURCE: SIR MY DAV-DZ110 HOME THEATER WAS FLASHING "PUSH
ola tengo un problema esk yo tengo el sony dav-dz110 cinema esk cuando enciendo me sale push power protector no se por k sale esto si alguien me ayuda se lo agraseria
