LG LFC25760ST 25 Cu. Ft. Panorama French Door Refrigerator w/ Glide N' Serve Drawer & Internal LED T... Logo
A
Anonymous Posted on Apr 14, 2014
Every once in a while the fridge will beep
Every hour or so the fridge will beep what would be causing it to do this
Why does it keep beeping even though the doors are closed?
  1. Check to see if the fridge and the freezer are overfilled Over-stuffing in the freezer or the fridge or both of these compartments will prevent the doors from closing properly and which can cause the fridge's to set off the beeping alarm.
  2. Check the fridge door seals: Broken or damaged door seals may stop the fridge from closing all the way. This can also happen if the seals are dirty. Wipe clean the door seals with a soft cloth and warm and use soapy water and close the fridge doors. If the door still appears ajar then you have to replace the door seals.It is also quite possible that the inbuilt door-alarm which sets off if the fridge door is ajar for more than a few minutes has gone bad . This would need to be looked at by a qualified repair person . Until, you can call a repair person transfer all the food items to another cool place.
  3. Check the fridge balance: To work correctly the fridge must be placed on a levelled surface. Even a slight tilt in the fridge structure can set off the beeping alarm. Check to see if the fridge is balanced evenly.
  4. Check to see if the fridge exterior is warmer than usual: Check if there is adequate distance between the fridge and walls to allow for proper ventilation. If you have already ensured this and the fridge exterior still appears warmer than usual, have an appliance engineer to take look at the problem. If the beeping continues, switch-off the fridge.
  5. Check the freezer: If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm to go off . If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
  6. Have a repair person check the circuit board: It is possible that there is an issue with the appliance's circuit board. If so it will most likely need replacement.
2answers
My lg fridge wont stop beeping
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
2answers
Our Hotpoint Future Frost free FZS175 alarm is beeping and it is defrosting. Can we fix this ourselves?
Check the freezer: If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
https://www.appliance-insurance.co.uk/appliance-insurance-articles/6-causes-beeping-fridge/
1helpful
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
LG Side by Side refrigerator - ongoing intermittent beep - not door alarm
Have you cleared and cleaned the condenser and checked the water filter?
Its beeping and there is a d flashing where the fridge temp should be? we had just returned home from a shopping trip and noticed the fridge and some of our plugs was off. the trip switch had been thrown...
you dont say what make it is BUT the unit has got warm enough to start defrosting itself,(hence the beeping)after a full defrost it should start back up no problem.it may take 24 hours to settle down.
9helpful
2answers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 • Freezers
201helpful
16answers
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
