Was out riding and after stopping a few times it would not start. Battery cranks but will not turn over
SOURCE: Rolled our 2007 800 SXR - ended up upside down.
i would remove all of the water and then manually turn the engine over alot without starting it SOON to get the water out of the pistons- if it was hydro locked this might prove quite challenging.
SOURCE: ISchematics for 89 kawsaki jet ski
Go to the site below where you can see a parts diagram for your specific WATERCRAFT. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
If looking for an electrical schematic this site will not help. You will need a service manual for that.
SOURCE: Electric Starter Sticking I have a 2000
Sounds like a stuck starter solenoid,if you can get to the solenoid tap it with the handle of a screw driver,might take a sharp rap if it quits cranking then you will need to replace it...
SOURCE: 1995 kaw jet ski 750st push start button and it
No cranking ! After you push your button , just clicks, try to bypass your start solenoid at your ignition box. I would pull out spark plugs first. Just take a screw driver and cross the main battery post to the starter post at the box. If it turns over than your start solenoid is bad.
