Frigidaire Affinity Series FASE7021NW Logo
H
HEATHER Posted on Apr 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error codes beginning with letter E - Frigidaire Affinity Series FASE7021NW
paul
Level 3:
  • Master 825 Answers
  • Posted on Apr 15, 2014
paul
Master
Level 3:
Answers
825
Questions
0
Helped
173963
Points
2202
Where do I find the 4 diget code to AEG BPE742220B Ovn
If there is a fault happend the error code should appear on the display (as shown picture below) :
error code will appears on display-x2i5s4yosfxg1xpsbuvvkqua-1-0.jpg There are two types of error code, first one that begins with a letter "C" and a mean customer fault code that can eliminate by the customer.
for example:
C1 - means "Telescopic runner inside during pyrolyse"
Remedy: "Remove side grids during pyrolyse"
Faults that begin with letter "F" require the expertise of a service technician especially when it comes to new ovens powered and controlled by electronics.
for example:
F 239 means: Quantum Touch Controller alarm:
1. If the communication over the bus SPI with the Quantum touch is after 50 trials unsuccessful than alarm is set. The alarm is reset if the communication is okay again.
Could be:
1. Connections Board Touch.
2. Board Touch fault.
Dado
Error code 1h on kenmore he plus2
Oddly, I don't find this error code. In fact, every one of the error codes for the Kenmore He2 begin with a letter, not a number.
Kenmore HE2 Front Load Washer Error Codes Sears PartsDirect
How long does a first class letter from zip code 54601 take to get to zip code 14004?
Likely, 3 days. In my experience mailing from a zip code that begins with the number "2" to a California zip code beginning with a "9"...it typically takes 4 days. Mailing from zipcode 2_ _ _ _ to any zipcode beginning with a 1, 2, 3, or 4 takes 1-3 days. (Zip code numbers increase as you move west across the USA, and I think the LONGEST a 1st class letter usually takes is 4 days.)
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Renault Megane radio
For the code to be checked the radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
1helpful
The washing machine is currently locked. The door won't open. I turn on the machine and it begins to wash the clothes that are inside. But after a couple of minutes, the machine stops and on the screen the...
F21 is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed.
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the pump strainer. There are three screws at the very bottom of washer. You will need and extension and a star tip. I used a 9/32 socket to remove them. The front cover slides right off. Facing you is the pump strainer. Big white piece of plastic right in the middle. Turn the large white knob counter-clockwise to remove it and clean. It is the only thing you can unscrew by hand. Open it and clean anything you find out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 • Dishwashers
3helpful
How do I determine the year my GE model TFX24R was made?
Print How to Determine the Age or Manufacture Date of a GE Appliance
The manufacturing date and year is coded into the serial number of the appliance. Our serial numbers begin with two letters. The first letter identifies the month and the second letter identifies the year. The corresponding letters, months, and years are below. For example, if the serial number begins with the letters "FJ," the appliance was made in March of 1952.
Letter Month (first letter) Years (second letter) A January 2001, 1989, 1977, 1944 B -- 1945 C -- 1946 D February 2002, 1990, 1978, 1947 E -- 1969, 1948 F March 2003, 1991, 1979, 1949 G April 2004, 1992, 1980, 1950 H May 2005, 1993, 1981, 1951 J -- 1952 K -- 1953 L June 2006, 1994, 1982, 1970, 1954 M July 2007, 1995, 1983, 1971, 1955 N -- 1972, 1956 P -- 1973, 1957 R August 2008, 1996, 1984, 1958 S September 2009, 1997, 1985, 1959 T October 2010, 1998, 1986, 1974, 1960 V November 1999, 1987, 1975 Z December 2000, 1988, 1976 AY -- 1965 BZ -- 1966 CA -- 1967 DB -- 1968 VU -- 1961 WV -- 1962 XW -- 1963 YX -- 1964
Not typing correct letters
Major fault. Daisy-wheel sensor is losing position.
Probably a a motherboard fault, and beyond economic repair. Sorry.
7helpful
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
