There is black oil coming out of my exhaust and I have to keep sorting revs as there all over the place on once engine is hot and ticking over
SOURCE: gilera dna oil light and also rev counter.
Have you had an oil gauge on the line to check what pressure you are running at? You may want to try running a heavier oil in the engine. If you are running a synthetic oil switch back to ester oil. If this does not remedy the problem then a new oil pump will be the fix
SOURCE: '02 Yamaha XJR1300 Rattle/vibrating noise from bottom of engine
how do you adjust the headlight beam on a xjr1300 naked 2002 bike, is it as simple as undoing the 2 bracket bolts at the sides of the lights and re-setting the lights to a new level ??
currently it seems to be set for riding with a pillion passanger or heavy load at the rear as the lights are set low, no one flashes me even if i ride at night with full beam on !
thanks xjr cambs
SOURCE: 2001 r6 keeps pushing all the water out of the expansion tank and when hot does not want to run
Possibly has air in the coolant system causing the coolant to boil. You can flush the whole thing if your coolant is in need, but mainly open the radiator cap and shake all hoses to release air while adding more coolant. Also may be the radiator cap spring (maybe). I am not sure about why it will not start up... maybe a sensor will not allow it.
* I am not certified in anyway and have minimal knowledge, my 05 r6 had air in the coolant and would boil out of the overflow. Make sure you use distilled water to avoid corrosion.
