2005 Mitsubishi Endeavor Logo
Alex Morales Posted on Apr 14, 2014
P1751 TCL/ASc indicator/TCL indicator, TCL OFF indicator
Justin Clarke
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Apr 14, 2014
Justin Clarke
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
6587
Points
71
Try replacing the fuse for the backup lights. Mitsubishi Galants have had this problem happen a lot as well. Don't know why it blows, or why the backup lights also are used for the same circuit, but that should fix your problem.
My tcl/anti lock brake lights came on, and won't go off.
you probably have a code in the abs module that needs to be checked out and repaired. it could be a broken wire or bad sensor on the car. the tcl uses the abs module system to indicate any problems.
Mini Cooper S Engine Management Light
The following are descriptions from the Mini-Cooper S owner's manual.
Service Engine Soon "?If the warning lamp comes on
either continuously or intermittently, this indicates a malfunction in the emissions-related electronic systems."
EML light: "Engine electronics ?Malfunction in the engine electronics. You can continue to drive with reduced engine output or engine speed."
Triangle circled by an arrow: "Automatic Stability Control plus
Traction (ASC+T)/Dynamic Stability Control (DSC)
?Indicator lamp flashes: System active: drive and braking forces are regulated.
The indicator lamp stays lit: ASC+T/DSC switched off with button or defective. In the event of a defect: please have the system inspected at your MINI Dealer."
First, inspect the belts to make sure none failed at high RPM. If one broke, inspect any cable or hoses in the plane of the belt to see if there was any damage (e. g., a ripped wire in the ASC+T/DSC system). Second, get a readout of the engine error code. (If you get indications of a major vacuum leak including rough idle, look for a blown head gasket.) If you get something else, please post the results in a comment so we can go to the next step.
1helpful
Trans stuck in limp mode i'm getting a p1751 code
P 1751 Shift Solenoid" A" performance. The solenoid is part of the transmission valve body and yes if this solenoid fails you will get limp mode.The only solution is a new solenoid may be even the wires to it or even the transmission module
4helpful
There is a symbol on the dash showing a circle with a traingle and and exclamation mark in the centre
This is the ASC indicator. It comes on when the system is turned off. To get the light out, turn the system back on by pushing the ASC(dsc) button on the console. It's located just ahead of the shift lever. ASC is the Automatic Stability Control system.
It's a traction control light. it warns whenever the system is turned on and the car senses a loss of traction. you can deactivate the system by pushing the ASD(dsc) button and holding. this light will illuminate to say: you may lose traction.
Can sometimes be activated by faulty brake(ABS) sensors,ABS pump,While checking ensure that your brake pads aren't worn right down.
If the light still stays up get your local service dealer to scan cars computer for fault code relating to which sensor is perhaps faulty.
I hope this helps you or get back with your findings
4helpful
My engine light is on and the machine gives a code P1751, what is that? It's a 2002 Mitsubishi Diamante
p1751= auto transmission control relay malfunction.according to mitsubishi it's 1 of 3 things.pretty straightforward.either the relay is bad,loose connector,or failed pcm (powertrain control module.
2005 Lancer, Fault Code P1751, Lost Speedo, SRS light
my mitshubishi lancar petrol car is consuming more fuel and giving black smoke
1helpful
Recently got a 1999 m5 the asc indicator does not go off even if the button is pressed .Can anyone tell me why? thanks
the ASC is for auto stability control,,you probably got a bad sensor, anything from abs to height sensor,,,,,you need to get the car scanned to see what then code is,,thats why the light is on,,it disables the asc and abs
1helpful
My ASC+T Indicator Lamp lights and car can't move...
When your ASC light is on this is to let you know your Automatic Stability Control system is switched off press the ASC button Till light is off /ASC is on this works with your rev limiter and should stabilized your idle. If the problem persists have your throttle control unit checked as this can trigger the ASC light as well and may also activate the ABS light if not fixed
9helpful
ALARM LIGHT ON THAT LOOKS LIKE A TRIANGLE WITH ARROW CIRCLING IT. WHAT DOES IT MEAN
On a 1998 3 series (E36) BMW, this indicator lamp is for the ASC+T = automatic stability control plus traction. It should go shortly after the ignition is switched on implying that the system is OK.
If the indicator lamp fails to go out after the engine is started, or comes on in the course of normal vehicle operation it means that the system has malfunctioned. The vehicle remains operational, but without ASC+T. You a have an 2001 3 series (E46), but I suspect the indicator lamp means the same as the E36 3 series. Look in owners manual under "indicator lamps"
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
