SOURCE: Sharp AR 235 error code E1-11
Abnormality on the IMC board.
Try resetting by pressing # / interrupt / c / interrupt.
punch 14 and ok / enter.
restart your copier.
if it doesn't work you will need a tech.
SOURCE: how to rest h2 code on sharp ar-235 what is the
Make sure the thermistor is clean and ok then press, P, Interrupt, C, Interrupt. It asks for a code, Enter 14 press print then press Execute on touch screen.
SOURCE: What does error code L6-10 mean on a Sharp AR-235
L6-10 Content Polygon motor lock detection
Detail It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
SOURCE: Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Testimonial: "Your help is much appreciated, regards: Márton"
