For motorola phones..there are no themes but we call it SKIN to install Skins you need to download software SKIMAN FROM NET IT IS AVAILABLE FREE ON NET.
after downloading the required software download skin files from net like on mobiles9.com.
then connect your phone to PC open SKIMAn and install the downloaded skin files,,then you will be having your THEMES ! ;;;dont skip 100% works !
Use "Skiman"..A.k.a "Skin Manager", and download the skins from ModMyMoto.com's download section..become a member for free to do this..there are no limitations with this site, and you'll NEVER have to pay anything. :]...Oh and you can get Skiman from that site also.
I put a bad skin and that happand to me, but what i do to fix that is use "Skiman" a.k.a "Skin Manager"..if you don't have it, then download the newest version..or maybe that's what you used to put the skin on your phone...Anyway, just open "skiman" and then plug your phone in, but make sure that skiman is open before pluging in your phone..I don't know why but it seems to work better that way..Then after it loads the skins on your phone, pick one that is an original skin that came with the phone from the list or use a skin that never made the screen go blank(Tip: The skin that is currently set on the phone should have a tick infront it's name) ..Then after clicking it, just click "More" in Skiman and then click "Set as active"..once you have done that just click more again and click "Restart phone"..and then your done. :D..Oh and if you still see the bad "Bad Skin" showing up when your in skins when useing the phone but skiman won't read it when on the computer, just download the same skin and install it back onto the phone..most likely the phone itself will show the skins name but skiman wont if it's currupted..so reinstall the bad skin and then delete it right after or whenever you have time and it should remove all the bad skins files from your phone..this would be a smart move cause if you don't do this, then someone might play around with your phone and select the "Bad skin" again and then you'll have to start from scratch.
First, you need to install Skiman.You can usually find this by doing a search on Google.Then download themes(mobile9.com).Make sure the theme is personalized for your V3i.Open Skiman and plug in your phone.It should detect your phone.Then click install.And click install at the bottom of the window.Look for the skin file you downloaded.And then it will install the theme.It may take a while, but it will look great.
download skiman (Skin file Manager) software and install it to your computer skiman can install your skins directly to your phone... i suggest to search it yahoo web
Hai dud,
You can do it
1. Download P2K commander and its associated driver
2. Install it on your system and run it in tasjbar.
3. Then also download Skiman in which you can insert your favorite skin,add pictures or delete,whatever!
4. After successfully installing P2K commander & all associated drivers connect ur mobile and click on Skiman it will pair ur cellphone.
5. In Skiman manager,Click on -->install-->(if any menu options come up then just click OK-->),directs u to a folder, select & click ur skin-->rest the software will do the job.
6. At last from "more"-->click on "Set as active",and restart ur mobile.
7. Tada....ur mobile is now with ur favorite skin.
Hope it helped u!
first you download motorola skin loader and then you download motorola themes .ski file format, now you connect the mobile into computer and run the motorola skin loder the add the .ski file and install into your motorola l7 mobile phone.
