SOURCE: My GE Front load washer (WBVH6240) has an odor
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
SOURCE: Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
